Super 55 Oliver Diesel
Shaun Murray
03-21-2007 06:26:59
I am looking at a Super 55 Diesel. However, I have been informed that it does not have any hydraulics. I would like to use the tractor for raking hay, however, my rake needs one hydraulic hook-up. Do all Super 55's not have hydraulics. If some do, can it be added easily to one that doesn't. Thanks for the help.
Shaun
just wondering
03-21-2007 11:28:05
 Re: Super 55 Oliver Diesel in reply to Shaun Murray, 03-21-2007 06:26:59
Shaun, Just wondering, is the 55 your looking at the nice painted up one that is on e-bay now ? If so I'm guessing that one will bring good money . real nice tractor.
Antiqueblue
03-21-2007 18:35:09
 Re: Super 55 Oliver Diesel in reply to just wondering, 03-21-2007 11:28:05
The one on E-Bay would be mine. Thanks for the nice comments. What do you think it will fetch?
Shaun Murray
03-22-2007 08:40:02
 Re: Super 55 Oliver Diesel in reply to Antiqueblue, 03-21-2007 18:35:09
The one on ebay is one of the ones I am looking at. I have another I am also looking at, however, it is not in as good of shape. Neither has external hydraulics. The one on ebay is a very good looking machine.
Thanks for all the comments. I will touch base later for more specific answers, if needed.
Thanks again,
Shaun Murray
Antiqueblue
03-22-2007 18:07:12
 Re: Super 55 Oliver Diesel in reply to Shaun Murray, 03-22-2007 08:40:02
Mr. Murray, I have more pics of my 55 other than what's on E-Bay. If you would like me to send the others, let me know. If you would like any others taken, I'd be glad to. BTW, I've posted some on this site.
Mitch Cundiff
Lewisburg, KY
Mike (WA)
03-21-2007 08:33:45
I was one who talked of building an external hydraulic setup, as the original ones are very difficult to find. I wanted to make an adapter that would place the valve in the stock location- ie, at the front right corner of the housing. However, I haven't pursued it, as the big problem is dealing with the relief valve; I was going to utilize one section of the "gang" type (bolt together) valves- but if you just bolted the valve to the housing adapter, you'd lose the relief valve. However, if you want to mount the valve somewhere else, its a fairly easy project. Shaun, if you want to email me at mmittge at compprime dot com, I'll send you pictures of a simple adapter and explain it.
rrlund
03-21-2007 09:34:42
 Re: Super 55 Oliver Diesel in reply to Mike (WA), 03-21-2007 08:33:45
Mike,just for my own info,can you just tap in with hoses and run to an open center remote valve. I was going to try it once,just didn't do it.We sold the one that we had with the correct Oliver valve,but I know where it hooked in.
rrlund
03-21-2007 06:33:20
It has a hydraulic pump if it has a 3 point. It probably just doesn't have an external valve. They aren't hard to install,just hard to find. There has been talk on here before of machinists building their own.
