help with oliver manure spreader
oliver gets it
03-20-2007 09:42:52
what were the wheel or rim color on a oliver superior manure spreder and paint codes and scheme would be a big help thanks very much to all who can help trying to redo a old spreader to new
SherryS
03-20-2007 12:48:30
 Re: help with oliver manure spreader in reply to oliver gets it done, 03-20-2007 09:42:52
It really depends on what model it is. That could be the yellow spreader or the green one. Can you get the model number off the tag on the front?
OLIVER GETS IT DONE
03-21-2007 13:26:34
 Re: help with oliver manure spreader in reply to SherryS, 03-20-2007 12:48:30
YES I THINK I CAN READ IT BUT I DIDNT SEE A NUM. IT IS A WOODEN ONE I TALKED TO THIS FELLOW IN PENN. LAST NIGHT THAT WORKS ON CLETRACS AND HE TOLD ME IT WAS PROBLEY A GREEN ONE HE ALSO TOLD ME TO LOOK IN THIS OLIVER HERITAGE MAG. HE SAID ABOUT ISSUE NUMBER 4 OR 5 I HAD FORGOT TO LOOK AT THAT TILL HE SAID SOMTHING THEN I REMEMBERED SEEING IT. THIS SPREADER IS IN ON A 1 TO 10 SCALE ABOUT A 9 JUST NEEDS PAINT TAKES ME BACK TO CHILDHOOD WHEN I PULLED ONE WITH A 77 OR FARMALL H
SherryS
03-21-2007 18:35:34
 Re: help with oliver manure spreader in reply to OLIVER GETS IT DONE, 03-21-2007 13:26:34
That would have to be a late model 7 or a 17. Both are 77 bushel spreaders. If the chain that drives the top cylinder is on the left, it's a 7. If it's on the right, it's a 17. If it's a model 17, it could be painted the Fleetline green, unless it's a late 17, then it would be Meadow Green. The model 7 would be the Fleetline green. The 17 was designed to be a "high-speed" spreader.
I did a story on the spreaders back in 2003.
