oliver 1955 conversion to cummins 5.9
scoot
03-15-2007 21:14:51
wonder what the cummins part# is for the motor mounts for this conversion? Also looking for 5.9 flywheel part # 3911425, does anyone know were to find one?
Wrenchbender
03-16-2007 09:45:06
 Re: oliver 1955 conversion to cummins 5.9 in reply to scoot, 03-15-2007 21:14:51
I'm not sure there is a Cummins part # for the mounts, but the agco #s are; 30-3429482 for the front mount and 30-3440737 for the rear. These are the ones used on the White 100, 120, 140. The PTO drive hub is 30-3429644. Those parts weren't too pricey from agco. WB.
VADAVE
03-16-2007 04:04:15
Why don't you go to Shep's site, he gives a real nice description of the conversion.
Also since the 1955 and 1855 are really the same tractor I would use the same parts. I believe Shep used a White 140 for part numbers.
j meyer
03-15-2007 21:24:49
Lets see if Merlin or Shep pop up for you. I had a friend ask me to look for a flywheel for a conversion, and I have had no luck myself. Good luck!
Doug Oliver
03-23-2007 15:00:19
 Re: oliver 1955 conversion to cummins 5.9 in reply to j meyer, 03-15-2007 21:24:49
Cummins Doesn't carry the engine mounts as a part number. I seen several variations of mounts made by the local cummins shop. I make my own and they look factory. Email me if you want pictures and specs. Thanks Doug
