Questions about New Oliver 1265 Tractor Purchase
Chris Campbell
03-14-2007 11:18:15
Hello,
I just purchased a new Oliver 1265 tractor. It appears to be in good shape but I have a couple of questions about it and wondered if anyone could answer them for me.
1. What kind of oil do I need to be using in it?
2. When I use an implement on the 3 point hitch and I lift the implement up, it oscillates or sits there an bounces. Generally this can be a low or incorrect oil problem, is there anything else that would cause this behavior? How do I fix this behavior?
3. Anyone had any experiences with this tractor that they would like to share? (good or bad)
Thanks,
Chris
EasyG
03-16-2007 10:37:26
 Re: Questions about New Oliver 1265 Tractor Purcha in reply to Chris Campbell, 03-14-2007 11:18:15
Chris, I'm glad to see that some one else out there has the same tractor as me. Got my 1265 several months ago. So far I am really pleased with it.
Hard Knocks
03-15-2007 09:25:55
My 1365 hadn't been run for awhile when I first bought it and the hydraulics were a little jumpy but after about 30 minutes use it smoothed out
Hard knocks
03-15-2007 02:45:34
Good tractors I have a couple of Allis 5040 and a 460 Long which are about the same tractor.Import Tractor in Canada has most parts for it
J Schwiebert
03-14-2007 18:17:47
You need to Contact the museum in Charles City and at least get an operators manual. 15W-40 will probably be your best bet. Is this your first experience with a diesel? Answer this on your 3 point. If you pick the load up and then sut the engine off how long will the load stay up. You either have an internal leak on your 3 point or your sensitivety adjustment is out of adjustment. More questions? They are a tough little tractor and good on fuel. Also you should be checking you 2 stage clutch adjustment. You do need a book. J.
Chris Campbell
03-15-2007 07:23:53
 Re: Questions about New Oliver 1265 Tractor Purcha in reply to J Schwiebert, 03-14-2007 18:17:47
Thanks guys, the information really helps. I will be picking up the tractor this weekend and it does come with the manual. I will check the sensitivity on the 3 point (little lever under the seat on the right side) and I will also check the clutch adjustment. I will probably also give it a good bath and replace all the fluids just to be on the safe side. Thanks again for the replies.
