550 mfg date carb problem tsx811
brb
03-13-2007 06:16:22
I would like to know mfg date, my# does'nt match any lists I've seen serail# 1 93 369 519 Carb?? Will not run without choke on full??? I rebuilt the carb, it's clean!! excellent fuel flow, I even used alternate tank to check? Have checked for manifold leak, not obvious if any? Draw at the mouth of carb will stick your fingers to it?? Got us all stumped, any ideas?? TSX811
J. Mash
03-13-2007 20:17:14
 Re: 550 mfg date carb problem tsx811 in reply to brb, 03-13-2007 06:16:22
Check the throttle shaft for excessive play. May be sucking a little air. Their is a bushing and seal that goes on the shaft. Kits with new shafts are available. Intake leak is a possibility.
J Schwiebert
03-13-2007 07:02:23
Looks to me like it is a late 1967 model tractor. You drop the 519 which is the gear code when checking the number. Have you put a vacum gauge on it? J.
