help changing narrow front to wide on1650
thhill
03-12-2007 20:35:43
We cant get the pinion gear off the top of the pinion shaft. Have the bolt out pedestal unbolted and hanging down. Anyone have trouble getting the tapered splines to go down. Just a bigger Hammer??? I dont want to hurt the power steering housing.
Noel Putman
03-13-2007 18:47:27
 Re: help changing narrow front to wide on1650 in reply to thhill, 03-12-2007 20:35:43
Question; can you put a 1650 WFE on a 1600 Tricycle?
Thanks
thhill
03-13-2007 18:53:48
 Re: help changing narrow front to wide on1650 in reply to Noel Putman, 03-13-2007 18:47:27
Yes most all of the models are the same. Just make sure ya get the short shaft out of the power steering unit. The long one on the trycycle stays with it.
Noel Putman
03-13-2007 19:07:53
 Re: help changing narrow front to wide on1650 in reply to thhill, 03-13-2007 18:53:48
First, Thanks for the info.
Will an 1800 or 1850 WFE fit on a 1600 NFE?
Thanks
J Schwiebert
03-13-2007 19:10:21
 Re: help changing narrow front to wide on1650 in reply to Noel Putman, 03-13-2007 19:07:53
Yes, but remember they may not look alike because there were changed made in them. The later ones turn shorter.
rrlund
03-13-2007 05:36:03
when you unbolt that cap,two bolts,there is a steel plug in there that you have to pry out with 2 screwdrivers,then a big bolt under that that holds the shaft in.
J Schwiebert
03-13-2007 07:04:44
 Re: help changing narrow front to wide on1650 in reply to rrlund, 03-13-2007 05:36:03
The idea is when you loosen the bolt it will become tight and push the gear out. My first thought was did you take the snap ring our or did it have one. It needs to stay in there.
thhill
03-13-2007 18:44:57
 Re: help changing narrow front to wide on1650 in reply to J Schwiebert, 03-13-2007 07:04:44
Thanks J. seems simple now . I'll try it.
thhill
03-13-2007 06:07:36
Ya ive got that all out. And the splined shaft wont drop down out of gear. On a wide front ive made a puller and pulled the short shaft out the top( gear and all). But on the narrow front thats not possible . Is it? Looks like it has to go down.
