Oliver 770 Radiator
Jim Bennett
03-10-2007 09:09:26
I need to replace an Oliver 770 radiator. I can get a radiator from a 77 which has the same dimensions as the 770 but the 77 radiator is non pressureized and the 770 is pressureized and I dont know if it will work.Any information will be appreciated. Thanks Jim
deene
03-10-2007 14:57:23
 Re: Oliver 770 Radiator in reply to Jim Bennett, 03-10-2007 09:09:26
all radiators when new are pressure tested to check for leaks..so thats not an issue...most older ones were tested at 15 psi across the board the only thing would be the filler neck and how the cap fits in regard to the overflow and such..dont think you have an issue there either...the only thing a pressurized system offers is a higher boiling point..if you dont work the tractor then it wouldnt even matter on that area
