105 lift arms question
newter haven
03-05-2007 19:07:40
They won't go down, darn it! Working fine, three weeks ago, just haven't used them, tried them today no action. I went through the archives with no luck. Hope it's something external , I just put the motor back in after working on the three speed. Help spare me please!! LOL!!!
M kuhns
03-08-2007 07:01:46
 Re: 105 lift arms question in reply to newter haven, 03-05-2007 19:07:40
You just can't push down the 3pt lever and go out back and jump on the arm without the arm responding to the 3pt lever due to the internal controls. Have someone put weight in the arms and move the lever from the up slowly to the down positon or they won't go down if you just jam the lever to the full down position.
newter haven
03-08-2007 18:29:31
 Re: 105 lift arms question in reply to M kuhns, 03-08-2007 07:01:46
Sorry Mr. Kuhn, I should elaborate, I know if one throws the lever completely forward nothing will happen, but as I was putting my weight on them I was reaching up and working the lever. As I said before, seems a little unusual something would break while sitting, don't you agree?
dad's88
03-08-2007 11:32:53
Well then mine must be busted 'cause that's how it has worked since Dec.24,1976. Want to hook onto the bale carrier, just push the lever foward go out and lean on the arms and they go right down. No big deal, really. With the slightest amount of weight on them they will go down every time. Just how mine works I guess. You did mean with the engine running, right? Wont move at all unless tractor is running due to built in safty.
dad's88
03-05-2007 20:58:20
Sometimes when it's cold out I have to push down on them to get them to go down if there's no weight on them.
thhill
03-05-2007 19:35:23
Do you have internal cylinder or the outside cylinders (Cat 2or 3) cold ya have gotten air in the hyd cooler lines when ya pulled motor and not gotten it all bled out. Does the rest of Hyd stuff work (power steering ect.) do you have any weight on them? Might help to put weight on them to work air out. ???
newter haven
03-07-2007 18:16:24
 Re: 105 lift arms question in reply to thhill, 03-05-2007 19:35:23
Thanks for replies, sorry I didn't answer sooner. It has internal cylinders. When I had the motor out, I didn't unhook the cooler lines just layed them down to the front. I did however unhook the power steering lines to remove the fuel tank. I've stood on them and actually jumped up and down no help. If it is air , what do I bleed? Hard to imagine something breaking while it's sitting. Thanks again!
