White 2-85 questions
IA farmer
03-05-2007 18:23:30
The manual calls for universal fluid in the transmission and 55 hydraulic oil in the hydraulic. Can I use a universal trans./hydraulic oil in both or IH Hytran? 80w90 isn't used anymore? Also, does anyone know what White calls the paint color for the frame? Thanks.
pullnut
03-06-2007 20:55:12
 Re: White 2-85 questions in reply to IA farmer, 03-05-2007 18:23:30
if your 2-85 is not a factory red stripe use only 80w90 in the trans/final drives and never use anything other than universal hydraulic/trans oil in the over/under...do not use IH hy-trans it wont take the heat that the over/under can make and it is not compatible with the clutch pack linings...deere and massey oil will work also
kkiowa
03-06-2007 19:23:11
The gray stripe Whites had black frames, the red stripes and series 3 tractors were charcoal gray .
Don-Wi
03-06-2007 00:41:38
Oliver origianlly used Type "A" which is now the Mercon/dex III ATF fluid, but some time after the White name change they started using hydraulic oil. Either will work fine in the Over/Under Hydraul Shift unit. IH's Hy/Tran will be fine in both the O/U and the hydraulics, and if you currently run IH you won't have to worry about fluid contamination between tractors from running 2 different fluids.
We run MF Perma-tran III, because we already run Massey and it keeps things simple. We buy our oil in drums, even though we only farm about 65 acres. It still works out better that way.
The final drive still uses 80/90 gear lube. It is completely separate from the hydraulic unit.
For changing the fluids, I recommend a manual, or atleast looking at one from even a 17-1955 Oliver (or a 2-105 White)because the rear ends are pretty much the same.
Hope this helps some. If you need help locating al the drain ports and fill ports, someone will surely be able to hepl you out.
Donovan from Wisconsin
thhill
03-05-2007 19:38:55
use Automatic Trans. Fluid in the hydapower, And hydraulic fluid in hydralics. 80-90 in rear end.
