what do i have? junk?
jamesholmes
03-05-2007 08:10:37
i found a oliver 70 seirel # 247174 kd. the parts on it are in ok condition. they can be cleaned up. is it worth me rebuilding it or sell the original parts i got 300.00 in the tractor. or is it junk. if i did sell the parts were do i go to do that . thanks to who ever helps. james nolensville,tn.
El Toro
03-05-2007 08:59:17
 Re: what do i have? junk? in reply to jamesholmes, 03-05-2007 08:10:37
Post a picture. Hal
jamesholmes
03-05-2007 09:32:34
 Re: what do i have? junk? in reply to El Toro, 03-05-2007 08:59:17
i will have pics of the tactor and its parts. 3 of 4 hold air. took it down to the block and she is stuck as of this min. it is soaking in mmoil. thank to everone i will have pics when the wife gets home to put on here.
El Toro
03-05-2007 10:49:28
 Re: what do i have? junk? in reply to jamesholmes, 03-05-2007 09:32:34
If the pistons are stuck you can drive them out with a piece of 2X2 oak and a big hammer. If the sleeves are wet sleeves, they may come out with the piston. Don't be too agressive with the hammer and damage the block. Hal
old
03-05-2007 08:41:50
Real hard to tell you thats it junk with out seeing it. I have a 77 that a friend said I would never get to run but since then he has driven it a few times. All depends on how good or bad you are at fixing things and how good or bad that tractor is. I know I have got a good number of tractor back up and running and most where thought to be junk
Ken B.
03-05-2007 08:39:44
Is it a runner? Are the tires holding air?
