Water pushing out of radiator
Boco
03-01-2007 18:55:06
Brought home 4-210 today only gets to 140 on dash but pushes out alot of coolant. Have read in book if theres no termastats it would push coolant could that be the problem and not head gaskets, it's foamy and not just bubbling out. It doesn't seam to have a miss and no odd smell at exhaust pipe. And no white exhaust when started up cold, just seams to run to smoth to have a bad problem. Thanks for any input and advice, brother thinks it would pull a new 32 foot IH disk. Thanks for any help Boco.
Boco
03-02-2007 05:49:59
 Re: Water pushing out of radiator in reply to Boco, 03-01-2007 18:55:06
Thank you M kuhns for your information I do feel its head problem but just appreciate any advice or others thoughts and advice, I run D10 N at work here in So. Il. 12 cly. do sound different. Thank you, Boco
AB
03-02-2007 20:24:42
 Re: Water pushing out of radiator in reply to Boco, 03-02-2007 05:49:59
I"d say it"s probably a bad head gasket. Shouldn"t be too hard to get to on that tractor. Let us know how it turns out.
m kuhns
03-01-2007 22:27:07
Check to see if thermostats are installed. More than likely you are dealing with a blown head gasket. If you go to replace it, there are a few different types available. Get the one that is for a block with sleeves. The fire ring is wider to seal against the block and sleeve, so it shouldn't blow as easy. Some 3208's only had I think grade 8 head bolts and they updated them to Grade 10 on newer engines. It should easily pull a 32 foot disc on flatter land. We pull a 28ft disc on our hills with our 4-150, with no weights or ballast.
Adam Sues
03-03-2007 17:36:36
 Re: Water pushing out of radiator in reply to m kuhns, 03-01-2007 22:27:07
M Kuhns, You mention that you pull a 28' disk on hills with a 4-150. I'm woundering how fast you go? I have a 25' 230 white feild cultivator, a 23' k23 case disk with 22" notched blades and a 5 shank tebbin ripper. How well do you think a 4-150 will pull these? I have been using a 2255 mfwd with michilen radials and it struggles. Enough traction but short on power. Do you think a 4-150 with 18.4-34 bias duals will do any better? Thanks
m kuhns
03-04-2007 03:16:09
 Re: Water pushing out of radiator in reply to Adam Sues, 03-03-2007 17:36:36
WE generally run 4th gear, under up the hills, direct on the flats and over down the hill. It doesn't matter what tractor we use the 2255, 2-180, 4-150, or the 2-150, they all run about the same. THe 4-150 just has a lot more traction, and would probably pull the tillage equipment you mentioned. IF you give the 2255 a little more fuel it will waken right up. Our 2255 with the 3208 pulls a 5,000 gallon tanker up some pretty good hills in 5th direct on the road. It has been that way for over 7 years. I'm not sure, but I think somebody got into the pump before we got it. IT might be running around 200hp. We have no calcium or wheel weights on the 4-150. You have to watch how heavy you load the rear of the 4-150 because it only has 1850 rears and we already snapped 2 axles on our. I think the tanker was the reason. THat is why we use the 2255.
