perkins 354.4 oil passage ???
JD Ogden
02-27-2007 19:34:36
On a perkins 354.4 on the left side of the block where the oil cooler was there are three oil passages. Two small holes one above the other and one lower to the left that is larger. What I need to know is if I can block off the larger hole? I am trying to figger out the oil routing becuase I am putting a combine motor in a tractor. thanks for any help JD
J Schwiebert
02-28-2007 17:31:27
 Re: perkins 354.4 oil passage ??? in reply to JD Ogden, 02-27-2007 19:34:36
This has been years ago, more than a couple for sure. A man put one of those in a Cockshutt for a pulling tractor. It blocked the oil flow somehow and he tied it up.You better check that out real well.J.
Fern(Mi)
02-28-2007 01:10:44
I'm not sure I understand, which is normal for me. Myself having found oil passages the hard way, I�ve just come to plug ever hole with a fine thread plug or bolt. Especially on block�s back side. Saves oil running everywhere on start up plus if hole is needed for something else later the hole and threads have been kept clean.
My less than a nickels worth.
Fernan
