Oliver 550 water pump
Patrick Wallin
02-26-2007 14:41:14
Need OEM #10560-071 water pump. Tractor serial # 123629-519, Model 45 0592. Wakieshaw 4cyl gas.
Tryed an A & I A-162899AS. It is to large. I have pictures and a outline of the backing plate if needed. The old pump has no good ID marks on it.
Thank you for any help you can give. Pat.
J Schwiebert
02-26-2007 15:27:20
 Re: Oliver 550 water pump in reply to Patrick Wallin, 02-26-2007 14:41:14
It is your money, but if it was me I would get a rebuild kit and repair it. Should last many years. More questions
Patrick Wallin
02-26-2007 16:03:40
 Re: Oliver 550 water pump in reply to J Schwiebert, 02-26-2007 15:27:20
That would be great if I could find a kit. Would need a complete kit, especially the shaft and bearing. Housing is OK.
J Schwiebert
02-26-2007 19:10:14
 Re: Oliver 550 water pump in reply to Patrick Wallin, 02-26-2007 16:03:40
Not a proble: Shaft and bearing comes as asssembly. I will send you an e-mail. J.
AB
02-26-2007 18:44:26
I see advertised rebuilt ones with core exchange for $65 and new ones depending on casting # for $80 - $135.
Patrick Wallin
02-27-2007 05:53:13
 Re: Oliver 550 water pump in reply to AB, 02-26-2007 18:44:26
Could you give me a website address to go to for these rebuilts and or kits.
Thanks. Pat.
J Schwiebert
02-27-2007 10:48:06
 Re: Oliver 550 water pump in reply to Patrick Wallin, 02-27-2007 05:53:13
I sent you an e-mail. Did you get it? Now I need to remember if your pump seat needs to be machined or if you have ceramic seat. Any GOOD Agco dealer can get you the kit.
Patrick Wallin
02-27-2007 13:30:01
 Re: Oliver 550 water pump in reply to J Schwiebert, 02-27-2007 10:48:06
It is a ceramic seat.
Patrick Wallin
02-27-2007 13:25:28
Yes, I sent you a return mail but it came back as undeliverable. I will include it here.
J. Thank you for your help! Pat Wallin (Manager)
CTM Auctions
P.O. Box 442
Rochester, WA. 98579-0442 Office 360-273-0254
Dedicated fax 360-273-0643
Cell 360-508-9056 Please feel free to call collect. We have an auction on the 4th of March for 45 cars and trucks so I will be unavailable at times, especially Sat & Sun the 3rd and the 4th. I go into the VA for a double by-pass and a new valve on the 8th of March.
The only numbers on the casting are a 4411 near the inlet and a 2017 on the top.
Thanks again. Pat.
