steering u-joint?
BRG
02-25-2007 20:47:52
I need to replace the u-joint on the sterring shaft down by the box. Any tips before I start this project? Thanks; Ben
BRG
02-25-2007 21:23:58
 Re: steering u-joint? in reply to BRG, 02-25-2007 20:47:52
I forgot to say it's a '51 88RC! Ben
AB
02-25-2007 21:36:16
 Re: steering u-joint? in reply to BRG, 02-25-2007 21:23:58
third party image
Remove bearing holder & bolts and bolt through u joint.
AB
02-25-2007 21:40:39
 Re: steering u-joint? in reply to AB, 02-25-2007 21:36:16
third party image
Disconnect steering front shaft from u joint. Then when you have bolt out of lower u joint, shaft should slide out. Use penetrating oil and tap lightly.
