shop manual revision
Super 55
02-25-2007 11:40:38
Here is the shop manual revision.
To provide even greater strength and to further improve the tractor, complete one piece forged steel stay rods replaced he tubular steel design beginning with tractor serial number 40 314 500. The forged steel stay rods are interchangeable with the fabricated rods. The forged steel rods are the only ones available for repairs. With the use of the forged steel stay rod, a new fabricated bar steel center axle member was also provided to replace the forged steel center member. To use the improved forged steel stay rod on the obsolete forged steel font axle center member it will be necessary to grind approximately 1/16 inch from the axle bolt hole bosses to accommodate the stay rod yoke.
When replacing the early forged steel front axle center member with the improved fabricated bar steel center member in conjunction with the old fabricated stay rods, i will be necessary to use a steel washer as a spacer on top of the new axle to make it fit the old style fabricated stay rod yoke.
