Co-op E3 1953
jon
08-29-1998 09:07:28
what would the equivelent Oliver be numbered. and would most parts interchange?
Gary Hearn
08-31-1998 19:09:23
 Re: co-op E3 1953 in reply to jon , 08-29-1998 09:07:28
The closest that I can come on an Oliver would be a Super 66/660. Both had a 4 cylinder motor, the Coop a 153 Buda and the 66 a 144 Oliver. The 660 had the same motor increased to 155 cid.
Weight wise they would be about the same, though the Coop was taller & the 3 Cockshutt 30's that I have run 38" rear rubber.
None of the major components will match up. In addition to the power plant differences your E-3 has a 4 speed (possibly w/ hi/lo) while Oliver ran 6 speeds.
Cockshutt built these Coop's and White Motor Co. did not purchase Cockshutt until 2/62, after they purchased Oliver in 11/60.
Hope that helps.
: : what would the equivelent Oliver be : numbered. and would most parts : interchange?
Jon
09-01-1998 16:33:36
 Re: Re: co-op E3 1953 in reply to Gary Hearn, 08-31-1998 19:09:23
: The closest that I can come on an Oliver would be a Super 66/660. Both had a 4 cylinder motor, the Coop a 153 Buda and the 66 a 144 Oliver. The 660 had the same motor increased to 155 cid.
: Weight wise they would be about the same, though the Coop was taller & the 3 Cockshutt 30's that I have run 38" rear rubber.
: None of the major components will match up. In addition to the power plant differences your E-3 has a 4 speed (possibly w/ hi/lo) while Oliver ran 6 speeds.
: Cockshutt built these Coop's and White Motor Co. did not purchase Cockshutt until 2/62, after they purchased Oliver in 11/60.
: Hope that helps.
: : : : what would the equivelent Oliver be : : numbered. and would most parts : : interchange?
To Gary Hearn thank you my dad had an E3 when i was kid I remember it Having hi low tranny.
