Gear pattern for 70
R Moline
02-24-2007 15:26:41
Does anybody know what or where we can find the gear patter for a 70 Oliver. We bought one and dont know where all the gears are. Thanks
oliver fan
02-25-2007 08:51:58
 Re: Gear pattern for 70 in reply to R Moline, 02-24-2007 15:26:41
5*****1 _____ 2**!*** ***!*** 6**!**3 _____ _ 4*****R
Remove all the ********'s and you've got it. If it was orginally on steel it might only have the first 4. All 70's only had the one reverse.
oliver fan
02-25-2007 08:53:20
 Re: Gear pattern for 70 in reply to oliver fan, 02-25-2007 08:51:58
Didn't work.
rrlund
02-25-2007 10:29:15
 Re: Gear pattern for 70 in reply to oliver fan, 02-25-2007 08:53:20
What the ******** were you trying to do there? ;)
rrlund
02-25-2007 07:22:53
they had a decal instead of a plate. Like cowman said,manual,or a decal from Dumont.
rrlund
02-25-2007 08:07:38
 Re: Gear pattern for 70 in reply to rrlund, 02-25-2007 07:22:53
If it helps you at all,the 4 speed on tip toe patern is,top neutral right and up first gear,left down second,lower neutral right up third left down fourth,right down reverse. i think 5th and sixth on the rubber tired will be top,left up 5th,bottom left up sixth,if you want to write it down and make a plate of paint it on.
Wisconsin Cowman
02-24-2007 20:25:45
Got a manual for it? That will tell you.
