Source for OEM style Electrical Connectors
Formerly PaMike
02-24-2007 12:59:12
I am going over my 1755 and a bunch of the electrical connectors are melted or broken and need replaced. I am talking about the spade terminals that are inside the heavy molded plastic insulator. I could use the typical automotive insulated spade terminal, but the insulation isnt very thick and I am afraid it would short out before long. Anyone know where to get these connectors, or am I being too fussy?
Thanks
doug wenig
02-28-2007 21:25:36
 Re: Source for OEM style Electrical Connectors in reply to Formerly PaMike, 02-24-2007 12:59:12
the connectors you need can be gotten at most automotive parts stores they are called GM type 56 ends hope that helps
j vickerd
02-25-2007 12:27:00
hi. I work in parts at a gm dealer, and the terminals you ar looking for, i assume have a slotted spade (male) and a female terminal that is spring loaded strap where the male slides in.
there are gm part"s for these terminals. also alot of aftermarket places have access to these terminals thru "pico" which supplies aftermarket connectors and terminals for all sorts of applications. the terminals i described i used to repair connectors on my 770, and super 55
rrlund
02-25-2007 10:32:51
I know what you mean,but I can't say that I know. Korves has wiring harnesses for the older ones,but I don't know about those style connectors on the newer ones. I'd try them.I don't think that's too fussy,it's original.
krm
02-24-2007 20:56:49
Try delcity.net and get a catalog or their web site.They have everything.
Formerly PaMike
02-25-2007 13:47:32
 Thanks in reply to krm, 02-24-2007 20:56:49
They have something that will work. Might not be exactly the same in looks, but at least it will keep my wires from shorting. Thanks again.
j meyer
02-24-2007 13:16:01
got a picture of what your speaking of? We got a bunch of terminals and such available at work, and you never know...we could have exactly what your looking for
