Oliver 550 clutch problem
Mike in New Yor
02-22-2007 11:52:37
Have a '61 with a 6 1/2 foot Smythe blower. It snowed here last week, 40 in. in 12 hrs. so I was working the old girl pretty hard. Stopped for a coffee break. Started it up with the clutch in and it wanted to move forward but the brakes would stop it. Could not shift it out of gear. Shut off the tractor and the shift lever worked fine. Started it up, stepped on the clutch and it would not go into any gear, ground terrible when I tried. Shut off tractor, found a road gear and went home, put her in my wife's spot in the garage. (Made her happy!) Tried adjusting clutch but no improvement. They are calling for more snow this week. I am mechanically inclined, rebuild engines for a hobby. Have parts and operators manuals on the way but not here yet. Does anyone have any solutions? Greatly appreciated. Best regards, Mike
JD in da UP
02-23-2007 07:41:13
 Re: Oliver 550 clutch problem in reply to Mike in New York, 02-22-2007 11:52:37
Your problem appears to be a dragging pilot bearing. If it were stuck completely, the tractor would still move ahead when you pushed in on the clutch. A warped clutch disc could do the same thing or broken pressure plate springs. Unless it's just ice in the pilot bearing that would clear up as it warmed up, you are going to have to split the machine and service the clutch. Your wife should love that! Good luck
RossIL
02-23-2007 11:23:30
 Re: Oliver 550 clutch problem in reply to JD in da UP, 02-23-2007 07:41:13
I'll second the dragging throw out/pilot bearing. I'd hope it's ice as well though. Let us know how you make out.
Ross
