Oliver crop 77D
B. Livingston
02-20-2007 09:50:25
Hi all. I found this site after I picked up my toy. The rubber looks new with a few titties still showing. Owner said it has some fuel issues. I jumped on it for $500. I've read all the archives and can't find what I need to know.
I'm having a little trouble finding out what year it is and a few particulars. None of the side covers are on it, however, I do know it has a 6 cyl. (Number on the lt side of the block is 183(or 5 as the top of the number is missing)220. Below that is M100. The serial number is 35167C77D. Model says Crop 77.
Anyone have any idea on the HP or year? Also, the wheels look like a rusty red with one of the rear wheels painted white. It has a bunch of red showing through.
Thanks all. This seems to be a great site! Brad
rrlund
02-21-2007 07:03:30
 Re: Oliver crop 77D in reply to B. Livingston, 02-20-2007 09:50:25
You asked about the horse power too. About 35 +or-
ejr-IA.
02-20-2007 10:44:46
The data plate is on the right side transmission case near the brake houseing.Get those no. and post them and someone here can tell you what you have.
B. Livingston
02-20-2007 11:37:05
 Re: Oliver crop 77D in reply to ejr-IA., 02-20-2007 10:44:46
Thanks, I'll do that. Right now it's setting in a field in 2 feet of snow. I'll try to get out there as soon as I can then post the numbers.
rrlund
02-20-2007 11:36:59
Maybe,if it has band brakes it's on the right side,if it has disc brakes,it's below the instrument panel. If you can't find a serial number,look up under the rear end and get the casting code number from right on the bottom,you can decipher the year at least from that. Yes,the wheels should be red. I'm guessing that the white one is REAL white,not Oliver clover white. So welcome,and ask anything you want. Cabin fever has gotten the best of a lot of us and we welcome a challenge.
