Oliver 60 engine questions
old
02-19-2007 13:41:01
Is it a wet or dry sleeved engine?? Does it have internal freeze plugs like under the valve cover etc. I went to start up my HG that has the 60 engine in it and found water in the oil and the radiator low so I know I have antifreeze in the oil. Other then that it would start but of course I didn't run it long just enough to get it to where I could pull it out of the way. Sure wish I could find a book on it but oh well haven't so far.
Thanks
Rogerg
02-20-2007 11:04:03
 Re: Oliver 60 engine questions in reply to old, 02-19-2007 13:41:01
I purchased an operators, shop, and parts manuals from the Floyd Co. Museum in Charles City, Ia. 641-228-1099.
Hope this helps.
Roger
Ron Grother
02-20-2007 02:59:46
sound like one of the o rings is bad on the sleeve
dad's88
02-19-2007 22:18:40
 Did I miss something? in reply to old, 02-19-2007 13:41:01
You have an HG with a 60 engine in it?
old
02-20-2007 09:13:34
 Re: Did I miss something? in reply to dad's88, 02-19-2007 22:18:40
Yep I know it should have a hercules engine in it but when I got it, it had a contential engine in it and it didn't run well. So I put an Oliver 60 engine in it and now it has the power to do something. Theres a picture of it in the web page
hoot 66
02-19-2007 17:45:06
Yes there is soft plugs under the valve cover. I once bought an engine that had been frozen and supposedly busted and when I started to take it apart I found a freeze plug loose under the valve cover. That was all that was wrong.That engine is srill running now some 30 years later
old
02-19-2007 18:19:52
 Re: Oliver 60 engine questions in reply to hoot 66, 02-19-2007 17:45:06
Thanks, that most likely what is wrong on this one since if I open up the block drain I get antifreeze but the radiator if I fill it will drop its water lever in an hour or 2 so I figure it has to be a leak up high in the engine.
Ken L.
02-19-2007 16:53:32
Quite often on ebay there are manuals for the 60 or just get an IT manual.
old
02-19-2007 18:17:47
 Re: Oliver 60 engine questions in reply to Ken L., 02-19-2007 16:53:32
If I-T printed one I would have one already but according to the back of the I-T manual I have on Olivers there isn't one.
Tim in NB
02-22-2007 13:18:01
 Re: Oliver 60 engine questions in reply to old, 02-19-2007 18:17:47
I have an I&T service manual for a 60. It is manual number O-2 dated 1953. it covers 60,70,80,90,99(4 cyl). At the time, this manual replaced O-1. I thought the O-1 manual was still in print by I&T.
Ken L.
02-19-2007 16:48:16
It's a wet sleeve engine. No frost plugs under the valve cover.
