Source for 88 Hydraulic Pump Seals?
Kerwin
02-13-2007 18:14:56
I recently tried to order new seals for my 88 hydro pump, but the local AGCO dealer can't order them. I haven't pressed out the old ones yet to see if there is a name/number on the seal. Any help in source or a seal supplier part number would be appreciated.
Even though the 88 is old (ancient by most dealer's standards), I'm surprised that AGCO doesn't sell these seals anymore.
MCL
02-14-2007 18:24:25
 Re: Source for 88 Hydraulic Pump Seals? in reply to Kerwin, 02-13-2007 18:14:56
I bought some a year ago at Plevna Implement in Indiana. They had them in stock. Should be a common item.
RJH
02-14-2007 17:00:32
Sorry, Drive gear shaft bearing, Torrington GB 2212 not 2216
RJH
02-14-2007 16:54:35
drive gear shaft bearing, Torrington GB 2216 driven gear bearing Torrington GB 1616 Seals National 472354 Make sure that they are GB in front of the number, there is also a bearing with just a B in front, they will not work available at any good bearing store
Centerplate
02-14-2007 04:11:17
Kerwin, I keep seals on hand for those pumps. I should have a set of bearings also if you need them.
Nick
Kerwin
02-14-2007 18:26:55
 Re: Source for 88 Hydraulic Pump Seals? in reply to Centerplate, 02-14-2007 04:11:17
What's your price on the seals/bearings? Thanks for the reply. I've probably asked some of the same pump rebuild questions in the past, but I've had enough other projects come and go that it is good to refresh the memory.
J Schwiebert
02-14-2007 02:34:02
Change the bearings while you are at it. The bearings center the shaft which also centers the shaft in the seals as well.
Kerwin
02-14-2007 18:08:38
 Re: Source for 88 Hydraulic Pump Seals? in reply to J Schwiebert, 02-14-2007 02:34:02
What's the best way to get the old bearings out? Thanks for the reply.
J Schwiebert
02-15-2007 03:37:35
 Re: Source for 88 Hydraulic Pump Seals? in reply to Kerwin, 02-14-2007 18:08:38
Press them out. On those bearings you always press only on the end the manufacture put his name on!. Also make sure you install them to the correct depth as well. Make sure you also change the oil and the filter at this time unless this is an early group one unit. If it was me, I would take the reservoir off and flush the unit out before I would reassemble the unit. More questions? J.
oliver123
02-13-2007 19:41:54
I dont know where you are located, but I have purchased the seals from a couple different Agco dealers here in Iowa (wouldn't cost much to ship 4 seals). Call O'Brien County Implement in Sheldon, Iowa at 800-320-6224 and ask for Tom - they will have the seals in stock. Otherwise, a good auto parts store should be able to get them too.
old
02-13-2007 18:47:04
I got seals for my Super 88 from a place in Clinton MO phone # is 660-477-3311. part 3XK2053 the CR13545 is also a number you should be able to find from any good auto parts store. The CR number is a equicvalent seal to the other number and is a common one
