DUMB QUESTION OF THE DAY!
MARK MILLER
12-13-1999 18:54:45
Anyone know where to obtain a retaining ring tool to remove large diameter internal retaining clips(Aprox.4" DIA)? Like the ones holding the bearings race in my Super 55 Axle housing.
Dick L
12-16-1999 11:55:01
 Re: DUMB QUESTION OF THE DAY! in reply to MARK MILLER, 12-13-1999 18:54:45
I bought three pair of snap ring plyers and none would hold on the slanted ends. However I welded an end onto the pair that would open wide enough. You can get these rings off with a small and large screwdriver. It will snap back into the slot untill you get the hang of it. It can be done and goes better if you can get help.
Dean
12-14-1999 05:57:36
Not a dumb question at all; your local NAPA dealer should be able to get one for you.
John
12-14-1999 15:46:11
 Re: Re: DUMB QUESTION OF THE DAY! in reply to Dean, 12-14-1999 05:57:36
Try here enter key words "snap ring pliers" in the search box
Art
12-25-1999 20:16:17
 Re: Re: Re: DUMB QUESTION OF THE DAY! in reply to John, 12-14-1999 15:46:11
For an alternative, you might want to go to your JD dealer's service dept. and have them show you the screw-type retaining ring tool that is used to remove/install the ring on the end of the axle.
