70 hyd pump
rrlund
02-12-2007 07:38:20
I was talking to a friend,he said he found a live hydraulic pump for an Oliver 70. I'd never heard of such a thing. I still haven't seen it,but he said it mounts up by the distributor,the tank and valve mount above the cultivator lift. He said it will only work with the throttle on the column as the push pull throttle is in the way of the tank. Has anybody else ever seen one of these? Also,I saw on the classifieds,a pump that mounted where the pan is under the PTO drive on a fleetline and up. That's a new one on me too.
dad's88
02-12-2007 10:14:04
 Re: 70 hyd pump in reply to rrlund, 02-12-2007 07:38:20
Yes, I've seen this exact unit, but they are not very common. There were two later 70's in our county that I know of that had this set up, probably could have been more. I don't know who made this kit but it looks very factory. I think it will only work on a tractor with the three gear engine because of the way the pump mounts to the governor flange, but I could be wrong. The only thing I didn't like about it was you had to cut a small hole in the right engine side panel to clear the pump. It's been a lot of years since I've seen one of these, but from what I recall they kind of had the look of a fleetline system, sort of.
FM
02-12-2007 08:33:58
I met a tractor puller that had a live hyd. pump on his 70 a while ago. It had a tank that bolted to the right fender, though. I wouldn't have minded having it but for the price he kept it.
Mike
