Help - Oliver 60 Engine Question
Dan Caldwell
02-11-2007 08:36:44
Hoping someone can help me - I am rebuilding an engine from an Oliver 60 which was brought to me in a box already disassembled. I am not sure how the oil gets from the block to the rocker arm shaft in the head. There is a tube on the shaft which looks like it should connect to a tube coming up one of the oil galleries, but I can't see anything there where it should go. Was there supposed to be a hollow head bolt through which the oil passed? Any info or pics would be appreciated!
Thanks,
Dan Caldwell
Chatsworth, Ontario
Ron Grother
02-12-2007 02:49:40
 Re: Help - Oliver 60 Engine Question in reply to Dan Caldwell, 02-11-2007 08:36:44
get your self a book it will help you out. if you need parts email me
J Schwiebert
02-11-2007 10:16:11
Yes one of the head bolts is hollow. Also the connecting rods you will note are offset. Make sure those suirt holes in the block are clean. More questions?
rrlund
02-12-2007 07:07:24
 Re: Help - Oliver 60 Engine Question in reply to J Schwiebert, 02-11-2007 10:16:11
I believe that hollow bolt goes in the right rear hole doesn't it? If memory serves me right.
J Schwiebert
02-12-2007 14:32:58
 Re: Help - Oliver 60 Engine Question in reply to rrlund, 02-12-2007 07:07:24
Not on a 60, oil is fed from the center main.
