Oliver 66 Broken PTO shaft and clutch hub
Nelson Lynch
12-13-1999 16:03:00
I probably need the PTO clutch hub that bolts (I hope)to the flywheel. The existing hub was probably damaged when the PTO shaft broke and continued to grind against each other. I don't have the broken shaft out yet. It welded itself to the transmission shaft. My manual states that the new bearing is ball bearings as opposed to the old bushing.
Can this bushing be removed without removing the flywheel. Where Can I get a new bearing if I need it?
