Re. Cockshutt pully.
Norm in N.B.
08-28-1998 17:04:40
I finally found a crankshaft pully, now I need to know how to tighten the crank nut and stop the motor from turning so I can tighten it enough. Any suggestion's would be welcome. I tried putting it in gear, with the brakes on, motor still turn's. Thank,s for any input..
Paul Stanley
08-28-1998 23:08:53
 Re: Re. Cockshutt pully. in reply to Norm in N.B., 08-28-1998 17:04:40
: I finally found a crankshaft pully, now I need to know how to tighten the crank nut and stop the motor from turning so I can tighten it enough. Any suggestion's would be welcome. I tried putting it in gear, with the brakes on, motor still turn's. Thank,s for any input..
Sorry to say, I had to replace a crank pulley on my 52 Willy's station wagon on the side of the highway in Ohio during the month of January. I had to take the oil pan off and place a chunk of wood between the crank and the block to keep it from turning. Hopefully you will have better working conditions. Maybe someone out there knows a trickier way of doing it. Good luck. By the way, where did you get your pulley? Always nice to hear about part suppliers.
