Repair of a cracked tire
Shawn B.
02-05-2007 21:59:50
We are currently restoring an Oliver 88 with a single front. The front tire has great tread but also a 2" long crack. I want to put something in the crack to prevent any further damage. This is just going to be a show tractor. What would you guys suggest?
Ron Grother
02-06-2007 15:56:53
 Re: Repair of a cracked tire in reply to Shawn B., 02-05-2007 21:59:50
take a chain saw on a old tire and take the peaces and mix with gas. paint it on the with a brush.
JD in da UP
02-06-2007 05:03:26
Try automotive goop in the crack if you only want a cosmetic repair. It's like shoe goo. Made by the same company.
Tpost
02-06-2007 04:57:13
Bill is right. You might take it off and put a hot patch on it (if you can find one)but if it is dry rotted you will probly cause more damage getting it off the rim. Front tires are cheep compaired to rear tires and you only have to buy one so not too bad. Then you wont have to worry about it.
Princeton Bill
02-06-2007 04:09:15
Shawn:
Even though it is just going to be a show tractor, I'd recommend a new tire. With only one front tire you are pretty much up a creek if it blows out or goes flat while in a parade, tractor ride etc. If it is a crack the tire probably has dry rot and there is not much you can do about that.
Shawn B.
02-07-2007 06:41:58
 Re: Repair of a cracked tire in reply to Princeton Bill, 02-06-2007 04:09:15
Thanks for the suggestions
1755
02-12-2007 14:09:03
 Re: Repair of a cracked tire in reply to Shawn B., 02-07-2007 06:41:58
I used Bead sealer on one of our rear tractor tires it is a bit runny but I put more on as it socked it up mite have worked beter if it was laying flat but it did not run out I did it last july so I dont know how it will hold up
