I am not Larry NE. Ill. but I will give you a little information that you didn't ask for. Oliver didn't build a 420 baler. Ann Arbor Machine Co. built hay balers (hay presses) in the 30's and maybe even earlier than that. I have a picrure of two balers being pulled by Hart Parr 18 -36's with P.T.O.'s. In the mid. 40's Oliver bought the Ann Arbor Machine Company of Shelbyville, Ill. and that is how they got into the baler business. Oliver continued to make the Ann Arbor style of balers into the early 50's, then they re-designed the big balers and also came out with a line of smaller balers. Oliver built the 50 60 62 620 520 720 710 smaller type balers, and the 8 100 101 102 103 and 104 larger type of balers. From the mid. 60's to the mid. 70's White Motor Co. sold one Oliver tractor line and two Oliver implement lines, (balers & corn pickers) to other non-related companys. The baler line was the last to be sold, and Hesston was the company that bought it. The Hesston 4500 baler was the first baler that they built using the Oliver design. They are also the only company of the orginal above mentioned three that is still in business building Oliver designed equipment. Hesston has owned the baler line for over 30 years, so I don't think you could get parts from them for a Oliver baler.
