3X rollover plow on a 1655
Anthony
02-02-2007 16:16:23
Can a 1655 handle a 3x16 rollover plow?
I know pulling it would be no sweat, but what about the weight?
MikeOwi
02-03-2007 16:18:56
 Re: 3X rollover plow on a 1655 in reply to Anthony, 02-02-2007 16:16:23
I don't know about a 1655 but I have a 5 bottom rollover (added a 4th bottom to my 4 bottom) that I run with an Oliver 2255. It cruises down the field and my only hurdle as getting enough height to roll it over while keeping the 5th bottom in the ground while plowing. Took some adjustment and 6 slabs on the from to make it work. I found that I could turn around by going in reverse and then when the from wheel was in the furrow, I could roll it over without a problem. Sure makes plowing a field a breeze!
J Schwiebert
02-02-2007 18:24:31
We had 3 customers who had either a 6341 or 6342 on 1650 tractors. You need the weight up front and don have too many clods hanging on the bottoms otherwise lifting gets kind of touchie sometimes. More questions? J.
jjc
02-02-2007 17:05:41
i use a white 6342 3x16 on an oliver 1755 . i use 1200 lb weights on front.i dont think i would use on a 1655
