Is Super 55 crank drilled for rod bearings?
Denis Larsen
02-01-2007 06:35:20
Hello,
I recently had a rod bearing tighten up on me. While taking the rod bearings apart and inspecting the crankshaft, I noticed that there are no holes drilled in the crank for oil passages to lubricate the rod bearings. Are all Super 55 cranks undrilled for the rod bearings? Hos are the rod bearings lubricated? I measured the crank diameters for the rods and it was 2.249" everywhere, which seems like good news to me.
Denis
J Schwiebert
02-01-2007 15:50:36
 Re: Is Super 55 crank drilled for rod bearings? in reply to Denis Larsen, 02-01-2007 06:35:20
The rods are also offset. Make sure you get them in correctly otherwise the oil hole in the rod will not line up with the squirt hole in the block.
Larry from md
02-01-2007 10:01:15
No the crank is not drilled for the rods. Oil is squirted down from the top into the small holes drilled into the rod its self. Check and see if the holes are open and that the numbers on the rod and cap are the same. The oil from the top is metered by the main bearing when the holes line up some oil gets through. you have the pan off so check those bearings too.
