770 rear axle seals
Mark N.
01-27-2007 21:39:38
This spring I will be takeing the axle housings off each side and replacing the main large housing gasket at the inside and then putting new seals and gaskets on the outside end. Are there any tricks to doing this that may save some trouble. Can I remove the housing off leaving the axle or does the axle and housing all come off together? Thanks.
Dean Barker
01-29-2007 14:04:28
 Re: 770 rear axle seals in reply to Mark N., 01-27-2007 21:39:38
Be sure to coat the outside surface of the seal housings with permatex, even it they have the boreseal stuff on them. We put 5 experimental tractors together when the boreseal stuff first came out. 8 of the 10 seals leaked.
Josh in Pa
01-28-2007 04:37:14
You can take the housing off with the axle in it. You have to take the top plate off the transmission, and remove the snap ring on the end of the axle that holds the bull gear on. Other than that it is pretty straight forward.
Josh
