Temperture Gagae ?
Rob NC
01-27-2007 18:14:06
I have a 1365,when I got It a few Mounths ago the temperture and fuel gage combination did't register a reading.I figure sending units bad,well i bought thr temperture sending unit instaled it and the gage now moves but it dont get into the normal range after a good period of running.Bad gage?
RAB
01-27-2007 23:53:51
 Re: Temperture Gagae ? in reply to Rob NC, 01-27-2007 18:14:06
You could have a bad gauge, but it could be the wrong sender unit, or engine not getting hot enough or resistance in the leads/connections. You need to check the temperature to see what is happening. May be no thermostat fitted.
May also be a bad voltage regulator on that guage supply. Regards, RAB
