Carb replacement
Rick Wuertz
01-24-2007 20:49:34
I have an 1800 with a usx37 marvel schebeler carb (aluminum carb) which I have rebuilt a couple of times and just cant make it run. What else can I use for a carb. I have heard that there is a carb on a JD combine that works real well. Any help would sure be appreciated. Thanks
J Schwiebert
01-25-2007 02:13:57
 Re: Carb replacement in reply to Rick Wuertz, 01-24-2007 20:49:34
I just make some copies for a man with a Deere with that basic carburetor and has the same problem. Send me an-email with your U. S. mail address and I will make you a copy. If you do it correctly and make all the checks including using the vacuum gauge they work well. J.
putz54143
03-28-2007 17:48:58
 Re: Carb replacement in reply to J Schwiebert, 01-25-2007 02:13:57
can i get a copy of that carb thing i just pick up a 1800b gas that has been sitting out side for at least 10 years. i worked on that farm 20+ years ago and saw that it just sitting there and got it cheep engine was stuck but i got it free and wateing on carb kit and head gaskets but any way it alwas had carb trouble when i work there. i could use the help to get her runing again. i also tryin to get the 88 standerd wf from him to fix up thank you tom
MIKE FRENCH
01-24-2007 22:53:28
A carb off a JD 7700 gas combine works well, hard to find now days. Hope this will help.
