Dash Knobs (550 Gas)
Chris Van der V
01-24-2007 18:30:43
How do you get the knob off the end of the choke and light switch on a 550 Gas? I am re-wiring everything, but cannot get the dash off coz of these darned knobs. Surely I do not have to take out the whole choke wire to get the knob out?
It is very cold up here right now, so I don't want to crack them by trying the wrong thing. I have tried moderate unscrewing to no avail, but will try harder plus lubricant if you tell me they are threaded.
Thanks in advance.
Don-Wi
01-25-2007 01:17:22
 Re: Dash Knobs (550 Gas) in reply to Chris Van der Vyver, 01-24-2007 18:30:43
Some knobes just don't come off that way. They all have a retaining nut on the back side of the dash that ya gotta unscrew. Pretty much gonna have to pull the choke cable. It's not that hard, so don't panic...;-)
Light switch knobs (for the turning switch style) are generally held on by a small set screw somwhere under it where it's out of plain sight from the seat. The push/pull light switches the knob should unscrew from the switch no problem.
Donovan from Wisconsin
Chris Van der Vyver
01-25-2007 13:17:28
 Re: Dash Knobs (550 Gas) in reply to Don-Wi, 01-25-2007 01:17:22
Thanks Don. Got them off right away. Choke lead out. The trick with the pull/push light switch was to unscrew the knob before unscrewing the rest of the unit.
Don-Wi
01-26-2007 17:01:07
 Re: Dash Knobs (550 Gas) in reply to Chris Van der Vyver, 01-25-2007 13:17:28
Glad to help!! That's about the only help I can be on a 550 though...
Don-Wi
01-26-2007 17:01:02
