difference in type A, F, H oil
newter haven
01-22-2007 16:06:01
Refilling over/under, was wondering what types will work and what not to use, type A is hard to find, have type F and H (mercon/dexron II). Any help is greatly appreciated!
klf
01-23-2007 13:06:01
 Re: difference in type A, F, H oil in reply to newter haven, 01-22-2007 16:06:01
Do you guys use H-T fluid for the hydraulic system too?
Don-Wi
01-24-2007 00:40:34
 Re: difference in type A, F, H oil in reply to klf, 01-23-2007 13:06:01
Yep, we buy Massey's Perma-tran III in 55 gallon drums and use it in all of our tractors. We have 2 Masseys and 2 Ollies that run, and this way we don't have to worry about any type of fluid contamination.....
Of course, we never really worried about it like some guys on here have if they have 3 different brands and they use 3 different oils, and they have separate cylinders for all 3..... That's waaayyyyy too much of a hassle, and I would just use 1 cylinder on every peice of equipment and not worry about the cross contamination.
Only time I worry is when a neighbor with poor maintnance records borrows something and you never know how filthy the oil is in their equipment...
Donovan from Wisconsin
Don-Wi
01-23-2007 01:04:13
The modern day Type A is Mercon/dexron III. Like Dean says, hydraulic oil can be used now a days without any problems. Might wanna try to flush as much tranny fluid out as possible if it's full of the red stuff right now though, then just change the whole system instead of mixing.
ejr-IA
01-22-2007 22:11:23
I use dextron II
Dean Barker
01-22-2007 19:48:52
Starting in the middle 80's, the factory fill was White hydraulic oil for the over/under. The recommended refill for any year over/under or hydrapower would be White/AGCO universal hydraulic oil.
newter haven
01-23-2007 20:07:34
 Re: difference in type A, F, H oil in reply to Dean Barker, 01-22-2007 19:48:52
Thanks fellas for replying, wasn't sure what was what anymore. Had a parts man tell me type F and A are the same. Type A is hard to find anymore, may use hydraulic fluid like you guys said. Thanks again!
Don-Wi
01-24-2007 00:36:02
 Re: difference in type A, F, H oil in reply to newter haven, 01-23-2007 20:07:34
That parts man would be WRONG. F is not the same as A. F was for Fords, and the A was for just about everything else.... I think the F is a little thicker and would make a car shift harder....
