Alternator on 66 Oliver 770
Rod Krischke
01-20-2007 21:48:55
Does anyone know if the alternator on my 66 Oliver 770 came that way from the factory or is it a conversion. There is no voltage regulator and it is a 12 volt negative ground.
770
01-21-2007 06:55:50
 Re: Alternator on 66 Oliver 770 in reply to Rod Krischke, 01-20-2007 21:48:55
My 1966 770 has an alternator...AND a voltage regulator. 100% original.
Rod Krischke
01-21-2007 17:59:10
 Re: Alternator on 66 Oliver 770 in reply to 770, 01-21-2007 06:55:50
On your 770 do you know what the resistance is across the terminals of the coil? Is it a standard 12 volt coil (less than 2 ohms) or a higher resistance coil (more than 2 ohms).
J Schwiebert
01-21-2007 06:19:08
We sold a 770 out of either the last or second last run of the 770 tractors, even had to put a front mounted belt pulley on it for the customer. It had an alternator. All alternators are negative ground as per U. S. goverment interference on equipment that new. If you do not have a regulator you have the later alternator which was furnished for repairs for the orignal alternator which did have an external regulator. This is all from memory, more questions I need to do a little research. J.
Rod Krischke
01-21-2007 18:04:09
 Re: Alternator on 66 Oliver 770 in reply to J Schwiebert, 01-21-2007 06:19:08
I need to replace the alternator, can I replace it with a GM alternator from the late 70s to early 80s.
J Schwiebert
01-21-2007 19:09:53
 Re: Alternator on 66 Oliver 770 in reply to Rod Krischke, 01-21-2007 18:04:09
I don't see why not. At one time we had about 5 or 6 vehicles that took those alternators when the boys were all home. Ten dollars for one in a junk yard, checked it out, new bearings and I had a spare on the shelf.
