oliver 70 govenor
Marvin KY
01-19-2007 19:49:38
On a 5 gear motor cranks and idles fine.Start moving throttle foreward and nothing happends,keep on going still nothen,keep on going and motor goes to full rpms.Coming back down with the throttle move it back,move it back,move it back and finally it will drop to idle.I cannot get any rpms in between.It will run at idle or wide open but no middle rpms. Anyone know what is wrong? THANKS Marvin
Marvin
01-20-2007 09:28:53
 Re: oliver 70 govenor in reply to Marvin KY, 01-19-2007 19:49:38
Went back,took closer look and have decided that both are worn to the max.I am going to atemp to rebuild my orginal.Thank you for the replys.I maybe asking for your help again in a few days. Marvin
Marvin KY
01-20-2007 05:39:40
Yes took apart. Everthing seemed ok. Bought another govenor,same promblem. Marvin
J. Schwiebert
01-20-2007 09:14:48
 Re: oliver 70 govenor in reply to Marvin KY, 01-20-2007 05:39:40
Well how much play do you have on the pins and weights? You don't ant any lost motion? How dis you adjust it? How mch slop is in your throttle shaft and the linkage holes from thecarburetor to the governor?
J Schwiebert
01-19-2007 20:01:38
Have you taken the govenor off and taken it apart? How good are the bearings and the pivot pins and weighta? Five gear engines are the best model 70 engines. J.
