J Schwiebert need your help
Wisconsin Cowma
01-17-2007 12:35:54
Ok I think I am going to put a Delco distributor on my 1655 from an 1800. I called the guy at Wisconsin Tractor. He said something with the tack drive. Where it was located. Will I be able to use the same tack cable I have? What other stuff can you think of that may give me problems. When I install it. I can get a new one for 135.00 without core.
J Schwiebert
01-17-2007 13:39:09
 Re: J Schwiebert need your help in reply to Wisconsin Cowman, 01-17-2007 12:35:54
I would most definately check into the electronic unit. If not send me a phone number. J.
oliver_t
01-17-2007 13:36:40
I would try the Petronix electronic unit for the Holly Dist. It has a replacement for the worn nylon base that is the problem in most of those. I'ts been successful on both my 1500 and 1650...
