stiched block
cameronz77
01-12-2007 11:47:15
I was just wondering if anybody has had any luck rebuilding a 77 block that has been "stitched"?? This is the first time seeing this. I dont wont to spend a lot of time and money on something that wont hold up.Thanks.
AB
01-12-2007 18:32:32
 Re: stiched block in reply to cameronz77, 01-12-2007 11:47:15
If it's done right it should be OK. On the other hand there are lots of stich free and weld free 77 blocks out there you could buy. If I was going to rebuild one and put alot of money into it I would try and get the best block I could.
noncompos
01-12-2007 16:25:06
I've seen welders drill holes at the ends of a crack in a block, putting in screws to fill the holes, the idea being it stopped the crack from spreading as the engine warmed and cooled, but the actual crack was welded or sealed with various stuff (block sealers, etc). Does anyone have any idea how just drilling a set of screwholes would hold the crack together? (The screws would seem to stress crack apart!).
MikeS55d
01-12-2007 14:49:18
I ran across this company's web site a few years back. They have some proprietary techniques and hardware. The examples shown on their web site are impressive.
http://www.locknstitch.com/
DennisT
01-12-2007 14:08:56
 Re: stiched block/cracked block? in reply to cameronz77, 01-12-2007 11:47:15
First, I'm not an expert on this; but I am going to tell you what I witnessed that seems related:
Years ago I had a good friend named John Ball, that was an, "old time," tractor repairman and machinest. In his later years he collected vintage tractors. One time I was at his place and he had a John Deere GP with a cracked block. Water seeping out on the hairline crack. He drilled a couple small holes into the crack, put a screw in each hole and ground the heads off flush with the block casting. Leak stopped; he was done. John was very matter-of-fact about it, simply saying that was what one does to fix such a problem.
That's all I know.
Dennis
cameronz77
01-12-2007 14:02:23
Thanks for the reply. As far as "stitched" I mean that there has been holes drilled into the block and screws inserted and then the heads of the screws ground off. On the distrubter side of the block (off of an oliver 77) there is a row of screws about 3 inches from the top of the block all the way across. On the same side of the block below the distributer mount and above the 2 inside mains are 2 screws each inline with the 2 inside mains. Thanks.
new kid in town
01-12-2007 20:23:57
 Re: stiched block in reply to cameronz77, 01-12-2007 14:02:23
they are probably not straight screws. we do crack repairs by stiching in some situations. they are a tapered iron plug, you drill and tap and install the plug.grind it off,then start over again,makig sure the next plug is partially in the last plug. we have repaired alot of heads this way. if it is near the deck of the block,i would be leery of it pushing the deck off more. you did say distributer side. that is the cam side.i didn't think there was water there. will look tomarrow to be sure.
JD dozer mike
01-12-2007 12:44:00
What you mean " stitched"? I have seen quite a few other engines welded where block was cracked, and they hold good. depends on where the crack is though.
TxAllisMan
01-13-2007 14:59:29
 Re: stiched block in reply to JD dozer mike, 01-12-2007 12:44:00
third party image
I worked in an automotive machine shop so quite a few yerrs and stiched alot of blocks and cylinder heads.
Ill try to post a pic of what stiching looks likes.
Damon
N.E. Texas
C #552
