560 engine
Barry Simon
01-11-2007 17:13:39
Does anyone have any info on rebuilding a 4-270 engine? What problems did you encounter and the like. How do these engines and the tractor perform in general? Thanks
cockshuttguy
01-19-2007 13:50:53
 Re: 560 engine in reply to Barry Simon, 01-11-2007 17:13:39
Barry, I'm responding to the second part of your question.
I have purchased 3- 560's in the past 8 years. All the engines were junk. One had a broken crank, another cracks in the block between cylinders and head and the other was damaged beyond fixing by a sandlotter. The 560 is a good tractor like all the cockshutts. The 4-270 engine has a weakness that other perkins engines did not have in general. It has only 3 mains for the crank.
It appears that a number of 560's if not properly maintained and watched had cranks break because of overheating due to a leaking power steering unit that assisted in plugging off air flow through the radiator. I've been told that a 560 with proper maintenance, etc. could acquire 10000 hours without any major problems, however, if not watched thoroughly could become a major problem earlier than expected. My plans are to re-power with cummins when we get the funds and the time for making a new adapter plate and newly configurated p.s. unit.
It appears that the 4-270 was not one of the best in the Perkins line.
My 2 cents worth.
Barry Simon
01-12-2007 14:45:31
Thanks, My book explains the crank process. What causes these blocks to crack like this? The spare engine I aquired has 2 small cracks between the close sleeve sets.Also this assembly had a hole the size of a quarter broke out of the head beside and under one valve spring.Weird!!!
Barry Simon
01-12-2007 14:15:22
No I do not have a kit located.I do have a lot of engine know how but limited on diesels.I have a service manual for this engine. My concerns are, I bought this machine tore down,it hade spun no.2 rod bearing, and the block has a small crack between no.1 and 2 sleeves but it is only as deep as the top lip of the sleeves. I have another crankshaft and 4 rods, but is this block junk? Thanks
J Schwiebert
01-12-2007 14:23:52
 Re: 560 engine in reply to Barry Simon, 01-12-2007 14:15:22
From your description I would say the block is O. K. Seeing it is better. I have a Perkins Bulletin on grinding those cranks. It is a little different process than just chucking it up in the crank grinder and having at it.
J Schwiebert
01-11-2007 18:55:40
How much diesel experience do you have. I would not do an inframe. I would set all the piston heights within 0.005, the valve recession within 5 also if I was doing the work and I would ballance the rotating assembly. Do you have a "kit" located?
