More on 550 external Hyd hookup-----??
Leaky Boot
01-11-2007 12:19:37
Ok--we cleared up all the openings under the plate with the 3 bolts holding it. Can you tell me about the 2 plugs located near the Hyd filter? One is faces forward and one to the side. Thanks for all the commments. It will save alot of messy work testing them out the hard way. What I need is a simple and cheap way to get a single hookup for a wheel rake hose. LB
J Schwiebert
01-11-2007 18:47:52
 Re: More on 550 external Hyd hookup-----?? in reply to Leaky Boot, 01-11-2007 12:19:37
I take it you are going to add a remote valve. Do you have the valve? Remember when the oil flows through the unit from the one port it has to flow through the external valve and then back through the other port otherwise your 3 point will not work. Is you rake cylinder single or double acting? Myself I would look for a 4-way valve with float. J.
