perkins question
JD Ogden
01-11-2007 10:17:11
The perkins I found to go in my 1855 project is build #tu70001u559469f can anyone tell me a litle bit about this engine? (horsepower year ect.) thanks JD
JD Ogden
01-11-2007 15:39:38
 Re: perkins question in reply to JD Ogden, 01-11-2007 10:17:11
Tanks for all the info. How can I tell if it is a dot 2 3 or 4
JD Ogden
01-11-2007 10:33:46
I dont have the combine just the motor I can get the pump #,s. It is out of a white and it is turboed other than that I dont know. can you tell if it is a dot2 or 4. I balso think I am going to have some oil cooler problems. thanks JD
J Schwiebert
01-11-2007 12:18:10
 Re: perkins question in reply to JD Ogden, 01-11-2007 10:33:46
Sure you don't have a dot 3 engine? If so the only application for the dot 3 in North America was in a White combine. Plenty of power.
J Schwiebert
01-11-2007 10:21:04
My book will tell me what parts make up that build number. Horsepower will depend a little on application. Also do you have an injection pump code? My book also does not have year of production. What was the serial number of the combine? J.
Michael Schwiebert
01-11-2007 13:40:50
 Re: perkins question in reply to J Schwiebert, 01-11-2007 10:21:04
According to the decoding guide, the "TU" portion of the engine number denotes a T6-354.4 engine. The next group of 5 numerals denotes the parts list that the engine was built to. This is followed by the code letter that denotes what country the engine was mfg. in. Next is a group of 6 numerals that is the serial number followed by the code letter that denotes the year the engine was built. I figured that someone would have put the parts list info online by now, but I haven't been able to find it yet if it's there. I have provide a link to a decoding chart that will decipher the engine number for you.
J Schwiebert
01-11-2007 13:58:53
 Re: perkins question in reply to Michael Schwiebert, 01-11-2007 13:40:50
FYI for everyone: When I left Perkins had used 3 different methods of engine identification and serial numbers. The combine engine is the third set up. The 1850 would be the first. Most 2-105 tractors fall in the second group. Mike: Thanks for the help. J.
