norrow front for 1850
bcha 1850
01-11-2007 06:59:29
I have an 1850 with an adjustable wide front end.
I'd like to switch it to a narrow front. What all needs to be changed and what tractors can I rob a narrow front off
Thanks
J Schwiebert
01-11-2007 12:16:29
 Re: norrow front for 1850 in reply to bcha 1850, 01-11-2007 06:59:29
When the 1800 tractor was introduced the narrow front end was of a better design. I would get one off of an 1800 or another tractor that has that front end on itrather than a smaller tractor. Here is why: They have a little heavier post and they are also a little taller. Do I remember casting numbers no. J.
JD Ogden
01-11-2007 10:27:28
It is a pretty straight forward switch you have to take the top off the steering box (the oblong plate with two bolts in it under the radiator) it,s kind of tight but byou can do it without removing the rad. and grill there is a large bolt under the cap that you need to remove and then it is just the bolts you see from the bottom. any of the 4 digit series olivers with power steering sould work and I think the ones from the whites also. good luck JD
