OC46 tansmission oil
phil_in_WA
01-10-2007 22:23:28
Actually 2 questions.
Working on the clutch type steering on an OC-46b
Q1 About how thick should the frictions band be?
Q2 What type of oil that you can buy at Napa or some other reasonably convinient supplier goes into the transmission?
Thanks in advance
J Schwiebert
01-11-2007 18:52:17
 Re: OC46 tansmission oil in reply to phil_in_WA, 01-10-2007 22:23:28
Does your tractor the have spot turn clutches? You mentioned bands too. If you have the bands recommended fluid is SAE 50 non detergent oil. Call the museum and get yourself a book. Are you talking stacj height on your clutches if you have spot turn unit. I am confused on which steering system you have. J.
neil k.
01-11-2007 16:27:53
Recommended rear oil is gl-90 from napa and the bands are like regular brakes. As long as rivets aren't rubbing on the drums. Have three of these machines. Great little workhorses. Any ? email is open.
