marraige is never easy 1850+1855 = ?????
JD Ogden
01-10-2007 18:33:10
Okay I"ve got lots of parts, two tractors in peices. The 354 out of my 1850 is junk crank is wiped out. I found a 354 out of a white combine a friend took out to put in his combine but never installed it, it is turboed and is suposed to be good will this motor fit in my 1852.5 (1850+1855). He wants 600.00 for it thanks for your time. JD
Mike (WA)
01-11-2007 09:16:30
 Re: marraige is never easy 1850+1855 = ????? in reply to JD Ogden, 01-10-2007 18:33:10
Maybe the "marriage is never easy", but I think it just got a whole lot easier with the posts below. What great information. How did we ever figure anything out BI (before internet?)
JD Ogden
01-11-2007 10:12:27
 Re: marraige is never easy 1850+1855 = ????? in reply to Mike (WA), 01-11-2007 09:16:30
I don"t know how we got by but it sure is an easy and quick resource. I always know if I have a question and I can"t find the answer in the arcives all I have to do is ask. I always look forward to the endless knowlage of our fellow tractor guys. As always thanks for the post JD
ejr-IA.
01-10-2007 20:42:23
I think that you can buy switching stuff off you 1850 motor over to the combine engine, bellhousing,clutch, flywheel,water pump,mounting plates.Brotherinlaw and I put a Massey combine engine in his 105 White.
Fred Whittaker
01-10-2007 20:32:18
The motor should fit. You will have to use the timing cover, front motor mount, dampner pully, water pump, bell housing, fly wheel, and the casting that bolts to the front of the head for the top radiator hose, thermostat, and temperature gage sending unit from the 1850 engine. You will also have to replumb the the air intake from your air cleaner to the turbo. Depending on where the turbo is located on the combine engine, you may need to run the exhaust up from the turbo on the outside of the sheet metal. I put a 6-354 with a turbo out of a 750 massey combine in an 1850+1855, as you call it (assuming that you mean an 1855 rear end with an 1850 tub). I had to run the exhaust as i mentioned. The turbo was mounted to the outside of the exhaust manifold, not to the top like a 2-105 white, which would have enabled me to run the exhaust through the hood. You will also need to make a fuel tank bracket for the motor's side of the tank, and make or modify the throttle linkage, since the 1855's tank sits lower than the 1850 tank, blocking the normal path of the 1850 linkage. Or you could get a tank bracket and linkage from a white 2-105. I hope this helps.
