compression tester
o
01-10-2007 17:34:13
what do i need to get to test compression in oliver 310 d,just a mod. no. or brand of one on todays market,thanks john
Jeff Oliver
01-10-2007 20:04:22
 Re: compression tester in reply to o, 01-10-2007 17:34:13
If it is an old one ( B,C )then I would say to accuratly check compression your gonna bee a diesel compresion tester. I saw one in a Harbor frieght catalog with all of the adapters. Not sure of the quality but they do make them. If your just wanting to see if you have compression at all most any tester will work, you'll just have to have someone to hold it in the njector hole while someone turns the motor over.
J Schwiebert
01-10-2007 18:23:34
Can I ask you something? Is this 310 for farming or otherwise (pulling) Is it a direct injection or out of an 1800 B or C?
o
01-11-2007 06:19:02
 Re: compression tester in reply to J Schwiebert, 01-10-2007 18:23:34
310 ,1750,pencil ,thanks john
