How Much Paint?
Tpost
01-10-2007 06:54:58
Thinking of giving the 1650 a going over. I have looked at some of the previous posts and didnot notice an amount. White/Green. Any other advice would be appreciated. I am leaning toward the Dupont paint but not final. Thanks.
Gary U in CA
01-11-2007 17:40:42
 Re: How Much Paint? in reply to Tpost, 01-10-2007 06:54:58
I'm in line with the 1+ gal of green and 2 qts of white. Just finishing up on a 950 using PPG paint. I've used Dupont products with great results and quantity should match closely (assuming grade selection is the same). How good of a finish (color sanding) will impact how thick you may want to lay on.
Hope this helps
Gary
Thanks for the Info.
01-11-2007 05:46:14
I appreciate the help. I am going overhaul/paint after my wife has our new baby I just found out about yesterday. YEAHHHHH! I guess I will wait untill next fall. I dont want to have the tractor apart and run out of funds before spring. I want to make sure the little one is taken care of first. Thanks again from a happy dad soon to be plus 1. (This is great I can use another tractor driver):)
Stu
01-10-2007 17:54:14
I used about 3 gallons of Agco meadow green & about 1 gallon of clover white on a 2255. I had the tractor tore down to the frame and painted the parts in pieces which used more. The most important thing with paint is clean parts. Good luck. Stu.
old
01-10-2007 15:19:12
When I painted my Super 88 I used about 3/4 of a gallion on it maybe just a little more. I had just enough left over to paint the side curtains on my 77 and that was it. You can see to S88 in my web site. With the 16XX being bigger it will probably take more then what I used. A lot depends on how you paint what you use to paint and how thick you put it on
El Toro
01-10-2007 09:56:05
I think you would need at least a gallon of the green. When you add thinner it make even more. If you use an HVLP spray gun it will cut out a lot of the overspray that's wasted. Talk to your paint supplier to see what he recommends. Hal
rrlund
01-10-2007 09:40:21
I painted a 1550 two years ago with less than a gallon of green and 2 Qts of Clover white.Engine was in but the sheet metal was off.
TC nwtn
01-10-2007 09:36:34
I painted an 1850 a couple of years ago and used 2 gallons of meadow green fron Agco and 2quarts of clover white from Martin Senoir. I had the motor out at the time and painted the inside of the tub also. You could get by with less but I wanted to put on enough. I also added hardener. TC
