Oliver deisel injector pump
Bowfish
01-09-2007 16:13:57
I am working on an Oliver mid 70s 1955 I think, can't find a serial number, it has a Roosa Masters injection pump, can anyone tell me the step to timing the pump?
bowfish
01-20-2007 14:07:20
 Re: Oliver deisel injector pump in reply to Bowfish, 01-09-2007 16:13:57
ok, i have tdc on the engine, how do i align the pump, pump needs to be on the #1 discharge port, correct?
bowfish
01-11-2007 07:11:59
ok, do i line up the marks on the gears at the pump, the way the drive gear is made it could be 180* off.
J Schwiebert
01-11-2007 10:17:43
 Re: Oliver deisel injector pump in reply to bowfish, 01-11-2007 07:11:59
You need to get #1 on compression stroke at say TDC since timing is 2 degrees before. Remember your mark (TDC) on the flywheel is for cylinders 1 & 6. Don't worry about any marks on any pump drive gears. Get your marks in the timing window to line up. Bolt it up, roll it back a 1/4 turn to take the backlash out and roll it in the direction of engine rotation till the marks in the timing window line up. Check the mark on the flywheel and rock the pump as necessary. Tighten it down, bleed it out ( I hope you put new filter(s) on. Good shop practice: pump work equals install new filters. Unless the pump tied up see why it is much easier to line the marks up in the window remove the pump and if you did not trurn the engine you are close. J.
ToddV8
01-10-2007 16:38:54
My book say 2 degrees BTDC.
