550 power take off leak
bobshaw
01-07-2007 23:19:22
I have a 1962 550. The power take off shaft is leaking on the inside of the shaft.( Not the seal). If you remove the bearing lock ring and the allen screw is there an o ring to replace on the shaft. If so what size is it? Is it a standard o ring or special?
